Need help finding explanations/walkthroughs of ICs
Discussion in 'Electronics Resources' started by Mach3Maelstrom, Jun 19, 2012.
  1. Mach3Maelstrom
    Jun 19, 2012
    10
    I'm looking through past designs and am trying to reverse-engineer how it was done (explanations not well documented).
    I can find the datasheets for the ICs, but I can't find many resources that explain HOW the IC behaves under certain conditions (i.e. Pin 1 goes LOW when xyz and Pin 2 reads when the voltage is 30% of the supply, etc).
    Could someone provide me with a resource or two where I can find elementary explanations like these? Here are two of the ICs I'm looking at as an example:
    - ISL4223EIRZ
    - LM2662M
    Thanks!
    EDIT: To help you help me, here are a few resources I'm looking through currently for datasheets:
    http://www.datasheetarchive.com/
    http://www.datasheetcatalog.com/
    http://www.datasheets.org.uk/
  2. shortbus
    Sep 30, 2009
    4,097
    1,695
    Always go to the manufacturers web site and look for "aplication notes" for the IC your interested in. They usually have a good explanation of the chip, better than the data sheet.
    Mach3Maelstrom likes this.
