Hi, I hope I'm posting this in the right forum. I have a Ryobi P230 impact driver that has lost its variable speed function. It only turns on and off. I suspected that a semiconductor had failed so I broke into the switch. I found a transistor-looking device (voltage regulator?) and remove it from the circuit. Sure enough, there was an intermittent short across two of the leads. I can replace it, but I can find absolutely no information on it. No site has a data sheet for it and no site has a compatible. I am hoping someone here can steer me toward a possible compatible component.
The failed transistor-looking device is made by Fairchild in what looks to be a TO220 package and has the following two designations on it:
N349AH
and below that is:
M0255507
Not even the Fairchild site has any info. I suspect that this component is pretty standard for this application. The battery that drives the motor is 18 volts. Any suggestions?
Thanks,
Jack
N349AH
and below that is:
M0255507
Thanks,
Jack
