Need help finding better transistor
Discussion in 'General Electronics Chat' started by Synaps3, Aug 27, 2013.
  1. Synaps3
    Jun 5, 2013
    89
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    That's an RF transistor, so it's apparently in an RF circuit. It's unlikely that a transistor with a high gain will have a significant effect on the circuit operation. But if you post a schematic of the circuit, someone may have a suggestion to help you.
  3. Synaps3
    Jun 5, 2013
    89
    It is in an RF transmitter and I am trying to increase the power output. Why would having more gain not have any effect on the circuit? Will the circuit not draw any more amps no matter what transistor I put in? I tried putting more voltage into the circuit, but once I got past about 9v, it stopped drawing more current (I think that's just because of the voltage regulator). It wouldn't draw any more than 0.17A. I'm looking to make it draw maybe 2 3x as much. I've checked almost all the components on the board and they are way overrated so I know I can put more power in without damaging other components. That's all I know. I'm new to this.
  4. studiot
    Nov 9, 2007
    5,005
    515
    Like the Man said
    Post the circuit and then we can help you.
    However that help may not be what you expect.
    If you fit a larger 3/4"(bath) tap to your basin, you won't fill it any quicker because the feed pipe is still 1/2".
    It may well be the same for your circuit.
