Can't work this one out, can anyone help? **Please note part (a) isn't really a question, blame my electrotechnology lecturer for that.. **
I think I get what you mean about the upper transistor being connected to drain, thought it was connected in series.. Does this not mean that the source from one goes to the gate of the next? Can't find any examples of MOSFETS connected in series ( or at least as far as I can tell, could be completely misunderstanding it, probably am to be honest)If I understand description correctly, your diagram is incorrect.
Is the upper transistor gate connected to drain ?
Are you sure that this is a series connection ?
Purely just because it came up in the past exam papers twice in a row. But yeah, think I'll give up on this one and pray it doesn't come up a third time, thanks for the help anywayI'd interpret having an upper and lower device as being in series, which is a common configuration.
What isn't clear is how many inputs there are.
If you don't know the answer and are unclear about the question, what is the point of answering them?
Unclear ?? How can it be?What isn't clear is how many inputs there are.
What is unclear in this sentence?The input to the circuit is taken to be the gate off the lower transistor
Try Google "cs amplifier with active load"I think I get what you mean about the upper transistor being connected to drain, thought it was connected in series.. Does this not mean that the source from one goes to the gate of the next? Can't find any examples of MOSFETS connected in series ( or at least as far as I can tell, could be completely misunderstanding it, probably am to be honest)
Will do, thanksUnclear ?? How can it be?
Well pardon me for breathing...Unclear ?? How can it be?
