Need help driving LEDs from a Nano8
Discussion in 'Embedded Systems and Microcontrollers' started by Budman231, Nov 23, 2012.
  1. Budman231
    Dec 22, 2011
    13
    I recently purchased some Nano 8 Microcontrollers to complete a project that drives some high power LEDs. The output is about 25ma@5v from each output pin which is way to low to drive the 2 high power LEDs I need.
    Can anyone point out how I might be able to drive these LEDs (.8A) from these low output pins ?
    Help would be appreciated.
    Bud
  2. IC-Man
    Jan 3, 2012
    26
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    A transistor or MOSFET would be sufficient, unless you have a large number of LEDs to drive.
    Are the two high power LEDs on the same output, or two separate outputs?
  4. Budman231
    Dec 22, 2011
    13
  5. Budman231
    Dec 22, 2011
    13
    Thank you for the reply. I would like to drive 2 LEDs off 2 different output pins. They will be different colors but both be the same make/model.
    Bud
