Need help determining change in voltage of sine wave.
Discussion in 'Homework Help' started by wmsnyder, Jun 19, 2009.
  1. wmsnyder
    Jun 19, 2009
    Hi all,
    I have a sine wave with a f of 2.2khz and rms value of 25v. The cycle begins at 0 and I need to know the change in voltage from 0.12ms to .2ms. I calculated the period to be .45ms and the peak voltage is 35.35v but I am stuck after that.
    Any help would be greatly appreciated.
    thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can substitute angle for time, you may find that the sine of the angle will have to do with the voltage. For instance, given the period of the wave, what is the time to go from 0 to 90 degrees?
