Hi, my name is Martin and I need help! For my senior project, I'm building an electric scooter. I'm using an motor controller off another scooter, it's the same 24v 160w-250w controller at www.electricscooterparts.com. BUT, it cannot supply the 2HP(1500w) motor I using, with enough power. Rather than buying a new controller I was think I could just stack the FETs, but that seems too risky(the chip might fry). Now I'm going to make a High Amp FET bypass board like this one, (http://www.atomicmods.com/Products/V22-Regulated-Power-Board__10107.aspx). I will use it to bypass the battery power supply from the controller, directly to the motor. But I do not know anything about building boards. Does any body know how I would go about doing this. Here are the specs of what I need to create:
24v
62.5Amp or higher continuous running FETs
Three prong throttle input
24v battery input
24v motor output
Output back the the 160w-250w controller for the missing throttle and motor cable(do you think I will need this?)
Any ideas?
24v
24v battery input
24v motor output
Any ideas?
