I am working on project that takes the body's temperature, but the output needs to be in the form of frequency.
I am looking at using a thermopile, LM358 op amp and a AD7740 voltage to frequency converter. Using the datasheet for the AD7740 and this link for the thermopile to LM358, http://www.instructables.com/id/Thermopile-Sensor/step3/Op-Amp/
I have created the schematic below, but I have some doubts if this will work. I have concerns in that the AD7740 needs a power in, so where does the battery get grounded? Also, Is there another temperature sensor that can be used to simplify this circuit?
I do apologize if I am asking redundant questions or if I am way off. I have been removed from electronics for the past 15 yrs or so and I am trying to get back in and reading everythnig that I can.
