Need Help Converting 8051 microcontroller to HCS12 assembly
Discussion in 'Embedded Systems and Microcontrollers' started by mikeknight, Oct 18, 2009.
  1. mikeknight
    Sep 23, 2009
    8
    Here's the code:
    //Define the Port PINS
    a_red bit p0.0
    a_amber bit p0.1
    a_green bit p0.2
    b_red bit p0.3
    b_amber bit p0.4
    b_green bit p0.5
    c_red bit p0.6
    c_amber bit p0.7
    c_green bit p2.7
    d_red bit p2.6
    d_amber bit p2.5
    d_green bit p2.4
    //Define RAM Locations
    multiplier equ 30h
    current_signal_duration equ 31h
    //DEFINE BIT ADDRESS
    signal_f bit 00h ;if 1 then switch to next signal
    //DEFINE Constants
    MULTIPLIER_DEFAULT DATA 20
    DURATION_GREEN DATA 10
    DURATION_AMBER DATA 2
    //TIMER SUBROUTINES
    timer:
    push acc
    push b
    push psw
    push dph
    push dpl
    clr TF0
    mov th0,#3ch
    mov tl0,#0B0h
    call check_timer
    pop dpl
    pop dph
    pop psw
    pop b
    pop acc
    reti
    check_timer:
    djnz multiplier,r1_check_timer
    mov multiplier,#MULTIPLIER_DEFAULT ;One second ended reload value
    djnz current_signal_duration,r1_check_timer
    setb signal_f ;signal duration ended move to nxt signal
    r1_check_timer:
    ret
    //MAIN Program
    org 0000h
    jmp main
    org 000bh
    jmp timer
    org 0030h
    main:
    setb EA ;Enable Interrupt
    setb ET0 ;Enable timer 0 Interrupt
    clr signal_f
    mov th0,#3ch
    mov tl0,#0B0h
    setb tcon.4 ;start timer
    loop:
    mov current_signal_duration,#DURATION_GREEN
    clr a_green
    setb a_amber
    setb a_red
    setb b_green
    setb b_amber
    clr b_red
    setb c_green
    setb c_amber
    clr c_red
    setb d_green
    setb d_amber
    clr d_red
    jnb signal_f,$
    clr signal_f
    mov current_signal_duration,#DURATION_AMBER
    setb a_green
    clr a_amber
    jnb signal_f,$
    clr signal_f
    setb a_amber
    clr a_red
    clr b_green
    jnb signal_f,$
    clr signal_f
    setb b_green
    clr b_amber
    jnb signal_f,$
    clr signal_f
    setb b_amber
    clr b_red
    clr c_green
    jnb signal_f,$
    clr signal_f
    setb c_green
    clr c_amber
    jnb signal_f,$
    clr signal_f
    setb c_amber
    clr c_red
    clr d_green
    jnb signal_f,$
    clr signal_f
    setb d_green
    clr d_amber
    jnb signal_f,$
    clr signal_f
    ajmp loop
    $include(timer.inc)
    End
    Thanks!
    Mike
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. mikeknight
    Sep 23, 2009
    8
    Can you help me find this. Is their any program that could do this for me.
    Or if you could just translate a part of the code that would be great.
    Most of it is repetitive anyways.
    Mike
