Need Help Connecting Speaker/Amplifier to Breadboard
Discussion in 'The Projects Forum' started by ClimateController, Nov 26, 2013.
  1. ClimateController
    Dec 23, 2012
    19
    I have bread-boarded a 555 timer based tone generator. I want to feed its output into a speaker or a pair of headphones. I have a 3.5 mm female audio jack but I can't figure out how to solder connections to it so that I can get audio in both the right and left channels.
    Here's the data sheet:
    http://www.cui.com/product/resource/sj1-351x-series.pdf
    Please help. Thanks in advance.
  2. Ramussons
    May 3, 2013
    562
    92
    For ANY of the sockets, (Female Audio Jack)
    pin 1 is ground
    pin 2 is Left Channel (tip)
    pin 3 is Right Channel (ring)
    Use Earphones or Speakers of Impedance (resistance) greater than 32 ohms for good results.
    Ramesh
