Need help choosing fast recovery diode alternative
Discussion in 'General Electronics Chat' started by doby, Jul 4, 2015.
  1. doby
    Thread Starter Active Member
    Aug 17, 2011
    43
    I want to build a 3A switching regulator circuit (12V to 4.5V) which uses a 1N3880 fast recovery diode. I can find it for purchase online but because it's not very common it costs about 10 times more than potential alternatives. Also the 1N3880 has D0-203AA (stud) casing and ideally I'd like one with a much smaller profile.
    IN3880 characteristics: 6A forward current (max), 100V reverse voltage (max), 1.4V forward voltage (max), 150-300ns reverse recovery time (max).
    Which factors are most important when choosing an alternative?
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Pretty much those. To find alternates, try a parametric search at Mouser, Digikey, Farnell, Newark etc. Fairchild, ON semiconductor, International Rectifier etc. would be good manufacturers to check out.
    The attached has good info from Fairchild about Fast Recovery Diodes.
    Good luck.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    All of them. Here's the first one I looked at.
  4. doby
    Aug 17, 2011
    43
    Thanks, I've been looking at them for the past hour or so, I just wondered if there were any values I could prioritise over others. Obviously I wouldn't pick one that went below the values the circuit would be operating at but as it's a fairly low voltage and ampere circuit that doesn't seem to be much of an issue.
    Would you say matching the recovery time is the most important factor? Most of them have recovery times far quicker than that of the 1N3880, would this be an issue?
  5. Ancel UnfetteredOne
    Member
    Jul 3, 2015
    36
    14
  6. dl324
    Mar 30, 2015
    3,377
    651
    Reverse recovery time and forward voltage drop will affect regulator efficiency. Faster is usually better. For a lower forward voltage, you can consider schottky diodes because you don't need a large reverse voltage rating.
  7. crutschow
    Mar 14, 2008
    13,498
    3,374
    I would use a Schottky type, as dl324 mentioned.
    They are all very fast (which is good) and have a lower forward voltage so are more efficient and require less heat sinking.
    Ancel UnfetteredOne likes this.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
