need help calculating current
Discussion in 'Homework Help' started by darkknight, Oct 7, 2009.
  1. darkknight
    Thread Starter Active Member
    Oct 7, 2009
    41
    I am starting to learn and i am having some problems with this exercise, i was wondering if someone could help me out the resistor of 4ohms is reall throwing me off
    by the current law i know the current leaving is the same entering It = I1+I2
    It=9A
    but at i1 i am getting 12a and i2 getting 6a
    please help
  2. crashcash
    Oct 7, 2009
    let's recalculate the value of Rt. the two 3 ohm resistors at the far right are in series. they add to 6 ohms. that value is in parallel with the 3 ohm in the middle. calculating that will give you 2 ohms. that 2 ohm resistor is in series with the 4 ohm resistor and will give you an Rt of 6 ohms. therefore It is 6 amps. (ohm's law) next the 4 ohm resistor has that same 6 amps current flowing through it. therefore it's voltage must be 24 volts. the remaining 12 volts (36-24) is across the 3 ohm resistor in the middle. therefore it gets 4 amps. because i1 is 4 amps and itotal is 6 amps, the difference of those 2 currents is 2 amps. that flows through the two 3 ohm resistors in series.
    hope that helps
    crashcash
    PS it's always a good idea to label all the components in the circuit.
  3. darkknight
    Oct 7, 2009
    41
    but adding all the voltages doesnt that have to be equal to 0 by KVL?? tahnks for you response, sorry if the question is stupid i am just trying to learn
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
  5. darkknight
    Oct 7, 2009
    41
    thanks for your help, i understand it better now
