Need help bypassing volume control in Creative Inspire D3030
Discussion in 'General Electronics Chat' started by speedazzLT, Mar 16, 2014.
  1. speedazzLT
    Mar 16, 2014
    I have a problem with my sound system, the thing is volume control went missing after I moved into another place, so I would like to bypass volume control, so I can have max volume on sounds, and minimum volume on bass, I took a look at this http://forum.allaboutcircuits.com/showthread.php?t=39747
    post, but I found it too complicated for me, so is there any chance for a simple ,,newbie friendy" scheme?
    I took some pictures of board inside:
  2. BMorse
    Sep 26, 2009
    2,675
    234
    Was the bass and volume hooked up to a potentiometer? (Did you have to turn knobs to adjust either one)
    If both were controlled by "knobs" then is there any way you can read the values on the back of each one? They should be labeled with whatever ohms ratings they have. If you can provide that info, I will have a solution for you.
  3. speedazzLT
    Mar 16, 2014
    Hi, thank You for your reply, and I managed to find my controller, but it was ruined, with no connector at the end, here is some more pics:
    One ,,knob" was broken before, so If I remember correctly, I ,,fixed" it simply closing electric circuit.
