Need help building voltage follower and amplifier for high bandwidth.
Discussion in 'General Electronics Chat' started by MrLeitexxx, Nov 23, 2011.
  1. MrLeitexxx
    Nov 16, 2011
    I need help designing a circuit which will act as a buffer (or voltage follower) and also an other circuit which will act as an amplifier ( lets say X10 linear gain). Both must work well for a frequency between 30Hz and 10kHz. they must be single supply, (+9V/GND).
    thanks in advnced
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Any half-decent transistor or Jfet makes a voltage follower good to 100 MHz.
    The value of the coupling capacitors and impedances determines the low frequency cutoff.
    10x gain is simple. Single supply is also simple.
