Need help building a wireless servo.
Discussion in 'General Electronics Chat' started by xTHExxFALLENx, Aug 21, 2013.
  1. xTHExxFALLENx
    Aug 21, 2013
    8
    Hey guys! I have an invention in mind that involves a servo that needs operate wirelessly. I would like to know if any of you guys can give me detailed schematics on what to buy and how to correctly place the components.
    P.S: The simpler the better. Thanks in advance guys:D!!!
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    Please define "wireless servo" in more detail.
    I have no idea what you are trying to accomplish.
  3. xTHExxFALLENx
    Aug 21, 2013
    8
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
  5. Shagas
    May 13, 2013
    802
    74
    Define wireless .
    Ir? radio ?
    At what distance do you want to be able to controll it ?
    Is IR an option?
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You're going to have to describe in detail your invention, also we're not a design service.
    PS secret idea inventions never get anywhere on the forums.
  7. mcgyvr
    Oct 15, 2009
    4,787
    973
    You do NOT need to describe your invention at all.. But you should go into more detail about how the wireless servo portion of it is intended to function. You can/should leave out any proprietary information about this invention.
    Shagas likes this.
  8. xTHExxFALLENx
    Aug 21, 2013
    8
    IR would be great, because I only have to be a few feet from the device to have it work properly. Sorry if I sound like a noob I have absolutely no knowledge in anything tech lol.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    Forget ir, xbee, etc. We aren't there yet. What do you need, what do you need it to do? Do you need the servo to go through a preprogrammed routine ( ex. Accelerate from zero to 500rpm, maintain500 rpm for 5 seconds, decelerate to 350 rpm and maintain that for ten seconds, reverse direction and accelerate to 2000 rpm and stop back at home position and wait) when it is sent a simple high/ low signal? Do you need to to advance at a ramping acceleration as long as a high/low signal is maintained? Do you need it to maintain position from instructions sent to it wirelessly from a smart sensor? Do you need it to respond to commands from an app on your iPhone? THIS is the kind of information we need to help you, and if you insist on being all cloak and dagger about it then **** off, and figure it out yourself. Nobody has the patience to offer free help to someone who won't be a team player.
  10. Shagas
    May 13, 2013
    802
    74
    If you just need to controll the servo wirelessly with IR in REAL TIME then you can just use a slightly stronger IR LED and an IR reciever module , like the ones that are used in TVs , stereos etc : http://www.gme.cz/tsop31236-p520-055 that part .
    You will need a 38khz carrier and a ~950 nm IR LED . You modulate the carrier with PWM and voila . When I say modulate , I mean turn it fully on and fully off with the PWM outline . The module connects to ground and 5v . It will demodulate the 28khz carrier and give you a clean pwm output which (i'm not sure ) but I think you can feed it straight into the servo.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    P.s. I'm not picking on you, it's just a sore spot for me because I am currently involved in a wireless servo project myself. My customer did not give me a clear description of what they actually wanted. From their original description it was made to sound very simple, 3 preprogrammed sequences, activated by 3 digital inputs, wirelessly. So I purchased a programmable servo controller and a simple 433mhz wireless relay board with fob to interface with it. Then after I got it working they wanted this and that and the other, they stacked so many requests onto it that the relay was no longer feasible, nor was the programmable controller capable. So I ended up back at square one. I had to do all the logic in a PLC and transmit ASCII instructions to the controller using wireless rs485. I'm still not done, it is waiting for me when I get back from vacation.
  12. xTHExxFALLENx
    Aug 21, 2013
    8
    Ok, all I need it to do is to spin at 180 degrees and stay there until I decide to switch it back.
  13. strantor
    Oct 3, 2010
    4,302
    1,989
    Ok, What kind of servo? An r/c hobby servo? A CNC servo? Does it have a controller? How do you interface with it?
  14. xTHExxFALLENx
    Aug 21, 2013
    8
    A r/c servo would be perfect and yes it needs a controller so that I can control it from a couple of feet away.
  15. strantor
    Oct 3, 2010
    4,302
    1,989
  16. xTHExxFALLENx
    Aug 21, 2013
    8
    Ok thanks a lot man.
  17. strantor
    Oct 3, 2010
    4,302
    1,989
    I just saw your post #3. Did you follow the link on the video? They show you EXACTLY how to build it, with parts list, schematic, and very detailed explanation of everything. Is there something more you want than what's shown in the video?
  18. xTHExxFALLENx
    Aug 21, 2013
    8
    Yeah it's good but it uses the xbee, I need something that isn't proprietary/copy righted.
  19. strantor
    Oct 3, 2010
    4,302
    1,989
    Any way you go, you're going to be using stuff that is proprietary/ copyrighted. And that's not uncommon and not a problem. Open up an apple phone you might find a motorola chip - that might be bad example, I don't know brand chips are in an apple phone, but the point remains. in the video, they're also using PICs, made by Microchip, servos made by someone else, and pots probably made by Bourns.
  20. xTHExxFALLENx
    Aug 21, 2013
    8
    Ok thanks for the help man, I'll get working on it!
