Need Help. Bistable Multivibrator.
Discussion in 'Homework Help' started by nobody0725, Jul 3, 2010.
  1. nobody0725
    Jul 3, 2010
    What is the common and easy to do application of bistable multivibrator? I really need suggestions here.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. nobody0725
    Jul 3, 2010
  4. retched
    Dec 5, 2009
    5,201
    313
    The link will have the information you need.
  5. Ron H
    Apr 14, 2005
    7,050
    657
  6. nobody0725
    Jul 3, 2010
    So, the bistable multivibrator is the s-r latch? Is that right? So, to get a application I just need to find application of s-r latch, then convert it to trasistor? Am I correct?
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually 2 transistors are the simplest set reset latch. What is your application? Or is that the assignment (coming up with an application and designing around it)?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I vote for the cross-coupled gates. What can be simpler than a single IC, unless the circuit needs to use non-standard logic voltages?
    Why do you need to use discrete transistors?
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have some ideas (I'm sure you've seen them, the 555 toggle for example), but I'm waiting for the OP to explain what he is really after.
    One of the reoccurring themes in the homework section is we will help, but we won't do the work. If you are stuck for ideas there are many appliances (such as LED lights) can could be push on/push off. I have a mechanical unit over my bed for a reading lamp. As for circuits, there are huge numbers of sources out there.
    As for discrete transistors, it is possible this is an assignment requirement.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Your guess is as good as mine.:D
