Need Help Basic Electronic.
Discussion in 'General Electronics Chat' started by rrrr4950, Dec 23, 2011.
  1. rrrr4950
    Dec 23, 2011
    5
    Dear all
    I'm taking a test with basic electronic. Unable to figure out this question. What is a shunt?..... 2 answer I remember 1. High resistance 2. Low Resistance and other 2 dont remember. Can someone help me explain what is a shunt mean.
    Thank you for your help greatly appreciated.
    rrrr4950
  2. Jotto
    Member
    Apr 1, 2011
    159
    17
    high precision resistor with low resistance to measure current by a ammeter.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    You'll have to refer to what your instruction has taught you, as that is the answer thier looking for. The term 'shunt' in electrical/electronics has a number of aspects that it can be applied to. To 'go around', or to 'drain away' could be 'shunting'. 'Shunts' in current measurement are typically shorting bars of very low, and more importantly 'known' resistance.
  5. holnis
    Member
    Nov 25, 2011
    50
    A shunt..is a high precision resistor which can be used to measure the current flowing through a circuit.
    Using Ohm's Law we know that the voltage dropped across a resistor divided by the resistance of that resistor is equal to the current, therefore if we measure the voltage across a shunt resistor in a circuit, we can easily calculate the current.
