Need Help: Air Ioniser Circuit
Discussion in 'The Projects Forum' started by justin24, Dec 16, 2012.
Thread Status:
Not open for further replies.
  1. justin24
    Dec 16, 2012
    Hi Guys, currently our group is working on a project called "Negative Air Ioniser".
    We cannot make the circuit function like it should. Cockroft-Walton Ladder Network is the main circuit for our ionizer, but i am hesitant that the output is depending on a needle soldered to a wire, which tends to let the negative ions burst into the air.
    What factors may we consider to make the circuit work?
    I'm hoping that some of you may help us. Thanks.
  2. Dodgydave
    Jun 22, 2012
    5,133
    767
    When you say you cant get it to work, have you got a circuit diagram?
  3. justin24
    Dec 16, 2012
    Mr. Dodgydave, after plugging the circuit to the power source there is no obvious evidence that the ions are emitted and released out of the needles. So we are not so sure that our circuit is effective.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    Bertus
Thread Status:
