need help about phone line
Discussion in 'General Electronics Chat' started by alitex, Oct 13, 2009.
  1. alitex
    Thread Starter Active Member
    Mar 5, 2007
    122
    hi all
    i make project that can detect DTMF/SCK by sm8223 IC,but i want when i recieve call open phone line to send some command by AVR controller (mega16),
    is there method that i can open phone line?
    thanks alot
  2. rjenkins
    Nov 6, 2005
    1,015
    69
    Use a 56K Modem transformer, which is a little 600 Ohm one-to-one ratio audio transformer. These are available from many suppliers and quite cheap, or just desolder one from a scrap PC modem board.
    Connect one winding across the line using a small relay, that will take the phone line 'off hook' and allow audio to be sent or received via the transformer.
    Put some diodes across the 'local' side of the transformer to limit the audio level so line switching & voltage spikes don't damage your audio circuit...
