Need help about my traffic light project
Discussion in 'The Projects Forum' started by eddietang, Mar 22, 2016.
  1. eddietang
    May 26, 2012
    6
    Im doing a two way traffic light project, i have build the circuit in multisim and its run perfectly like one way red and the another way green and so on, but when i build the circuit in breadboard the two red led are keeping 'ON'. I had tried figure out by dismantle the circuit and rebuild again many time, changing the IC, testing the IC part by part but the problem still the same, anyone can help me? The project based are using 555timer, CD4017BE counter, and 74HC4072( 4 input OR gate), 74LS32 ( 2 input OR gate). The schematic are in the attach file.
    • sche.pdf
      File size:
      222.1 KB
      14
  2. TheButtonThief
    Feb 26, 2011
    219
    38
    Would need to see how you've wired it, a diagram of your breadboard layout for example
  3. GopherT
    Nov 23, 2012
    6,330
    4,079
    A CD4072 (0-18 v supply allowed) used in your simulation is not EXACTLY the same as the 74HC4072 that you are using in your circuit (absolute max supply voltage 7 volts).
    Your chips has likely been damaged by your 9V battery.
    Read Datasheets.
