need help about 555 timer..
Discussion in 'General Electronics Chat' started by harikanaidu, Mar 22, 2016.
  1. harikanaidu
    Nov 28, 2014
    76
    555 monostable.jpg Hi, I want to design adjustable timer for my application..I am using a 555 timer for that purpose.can a 555 timer drives the relay directly if i connect the 555 in monostable mode and relay at the ouput of the 3rd pin of 555..
  2. #12
    Nov 30, 2010
    16,685
    7,323
    It depends on which model of 555 chip and how much current the relay needs.
    You did not tell either of these.
    harikanaidu likes this.
  3. DickCappels
    Aug 21, 2008
    2,770
    669
  4. harikanaidu
    Nov 28, 2014
    76
    thankyou so much
  5. harikanaidu
    Nov 28, 2014
    76
    I am using NE555 timer..and relay used is 12v relay
  6. harikanaidu
    Nov 28, 2014
    76
  7. #12
    Nov 30, 2010
    16,685
    7,323
    The NE555 can supply 200 ma but you did not tell the current your relay uses. You told the voltage.
  8. DickCappels
    Aug 21, 2008
    2,770
    669
    Not all '555's are of the same design. Some might be more sensitive to this reverse current flow than others. As I recall, the original intersil application booklet indicated that this diode is a good idea for their (original) version of the NE555.
  9. harikanaidu
    Nov 28, 2014
    76
    Relay
    This is the 12v relay i have...Input current required by it is not mentioned
  10. harikanaidu
    Nov 28, 2014
    76
    Can you just tell me what are the other version of 555 other than NE555..
  11. #12
    Nov 30, 2010
    16,685
    7,323
    Lm555, TLC555, SE555, ICM7555, and a few others.
  12. harikanaidu
    Nov 28, 2014
    76
    Can you please tell me how to know the current required by the relay...It is not present in the datasheet even
  13. #12
    Nov 30, 2010
    16,685
    7,323
    Try Google 12V 0.36W 30ma
  14. wayneh
    Sep 9, 2010
    12,382
    3,239
    Look harder (elsewhere, Google is your friend). It's a 400Ω coil in the 12V version.
    Here.
