need for help
Discussion in 'Homework Help' started by KASSIMSAMJI, Feb 11, 2012.
  1. KASSIMSAMJI
    Dec 30, 2011
    5
    Hello guys
    i plan to design speed controller for 1Ø AC motor bt I dont wish to include Triac as converter since they costly much!
    I'm looking forward to grab what u have on this n which another device u suggest me to use to get task done!
  2. panic mode
    Oct 10, 2011
    1,329
    305
    triacs and thyristors are cheap
  3. Felo
    Member
    Feb 20, 2012
    91
    13
    You could use a diode in series this is done on many hair dryers
    -diode in series for half speed
    -no diode for full speed
    As stated by panic mode thyristor are cheap enough and will give you a greater span of control, I dont thing there is another practical and efficient way.
    On the unpractical / uneffient method I would suggest a variac, tension divider with a HUGE variable resistor, etc
  4. #12
    Nov 30, 2010
    16,704
    7,354
    I have 2 ceiling fans that use a tapped inductor in series with the motor to control speeds. It's old and simple technology, but it works.
  5. panic mode
    Oct 10, 2011
    1,329
    305
