need explanation ?
Discussion in 'General Electronics Chat' started by eng_alaakaa, Oct 7, 2011.
  1. eng_alaakaa
    Sep 21, 2011
    12
    for this design of envelope detector ,
    1- what's the function of D2.
    2- why the output signal is inverted.
    see attached pic.
      File size:
      100.1 KB
      55
  2. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
    The D2 is used as positive peak clamper and hence the out put appears as inverted that is with positive peak clamped to zero volt.
    eng_alaakaa likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    The direction of the diodes will determine which way the peak voltage goes.
    When designing a demodulator like this, be sure the capacitors don't short the audio but do short the RF. It is a common mistake.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    No, the negative peak is clamped to (one diode drop below) zero volts.
    The circuit is a voltage doubler (see Fig. 2).
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    They really should have used a small Schottky diode, like a BAT54. The BAT54's Vf is far lower than 1N4148/1N914 switching diodes.
  6. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
    Yeah Ron I first thought the same that -ve peak is clamped coz of diode's polarity but eng_alaakaa's scope's output is not conforming to that. Could you plz. explain?
