Need experienced engineer's help for project.
Discussion in 'General Electronics Chat' started by EIR254, Aug 16, 2012.
Thread Status:
Not open for further replies.
  1. EIR254
    Aug 16, 2012
    Ok, to start off, I know how to read a schematic, and I'm familiar with how to build a circuit. I'm just not knowledges on creating either of those mainly because I'm not familiar with the 1000's of IC's and other special components and functions. But I will post what I want and see if I can get some help. I want a circuit where I can replicate what another wire has running through it without adding or lowering the resistance of the original circuit. Say there's a wire running 12V/30A and it's pulsing this voltage at various frequencies. I want to cut that wire, run it into a circuit, and out of that circuit and the generator of the original circuit not have any more or less load, and the receiver still get the same circuit. Basically I have a motor doing its job, I want another motor to work identically as the first. But I will also want the strength of the second motor to be adjustable on the fly. I am working with 12V DC circuits. And yes, it will be going in my car. Sometimes we want to add more to our cars electronics than they can handle. And this is one case. But I'm a do it yourselfer who wants a simple part that does what I want without any excess features, nor do I want it mass produced over seas. Thank you for your help.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Sadly this conversation involves a vehicle modification and as such will probably be closed by the moderators. You can see the policy in the terms of service. You should look around for another forum with a different policy.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
    Papabravo likes this.
Thread Status:
