Need experienced advice to solve a couple of problems
Discussion in 'The Projects Forum' started by Seaker, Mar 22, 2013.
  1. Seaker
    Feb 3, 2013
    32
    This is an extension of a previous post concerning me building a water tank level indicator.
    After much searching and evaluating different solutions I have come up with three questions that I would like to pose to the more senior members.
    1. The voltage range for several solutions run from 5 volts up to 24 volts. As I do not want to have a automatic pump connected to this circuit I believe that the voltage required with be in the 5 - 12 volt range.
    My question is, should I use AC or DC voltage?
    A few designers call for AC versus DC as there are concerns regarding corrosion or a build up on the tank water level indicators.
    2. There are several design considerations as to the type of wires that will be immersed into the tank.
    From what I have been able to find out using aluminum wire is preferred to copper. A couple of designs call for the use of brass screws or bolts as the connection points.
    Years ago one could find aluminum wire easily but due to past problems it is a rare item or so I believe. If I was to go that route (Aluminum) is there a ready source of wire available i.e. CAT 5 cable etc.
    3. Most designs call for a buzzer to be installed to notify of a full water level. Some use a Piezo speaker, others a buzzer and even one using a door bell. I believe that the selection of the alarm will depend upon personal choice and voltage used.
    I am sorry about the length of this post but I want to provide as much information as possible.
    Here are few links to water level indicators:
    http://s2ptech.blogspot.com/2012/04/simple-water-level-indicator.html#.UU0eWjd3fa1
    http://www.extremecircuits.net/2011/09/simple-water-level-indicator-cum-alarm.html
    http://archive.siliconchip.com.au/cms/A_30607/article.htm
    http://www.electronic-circuits-diagrams.com/alarmsimages/alarmsckt6.shtml
    http://www.brighthubengineering.com...3-build-your-own-home-made-water-level-meter/
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Uncoated (uninsulated) stanless steel wire, or aluminium wire, are easily available from someone who does MIG or TIG welding, they buy these wires on large spools and should be happy to sell you a couple of metres of wire.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
  4. GopherT
    Nov 23, 2012
    6,319
    4,043
    Looks like it is a 3N100 or a 3N108. Some high voltage SMDs from Motorola.
    Google the Datasheets. Easy to find.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Wrong thread?
    Ken
