Confusing title, let me explain. I am not concerned about the power source as I can work with that or build one . This is a 5volt project.using a 3.3 volt fan...What I do need is this: a PWM that works a fan and continues to work the fan up to the point 3 minutes after the power is shut off. This is for cooling a project. So you turn off the power to the unit the fan is cooling but the fan remains on for three minutes then shuts down and stays off until the power is once again reapplied by the unit you are cooling. So far I have not yet tried to build anything. The PWM I am fine with, so don't need any help there. You might say I am becoming lazy and don't want to spend the time thinking. Not that I don't enjoy it, as I really do, but it is becoming harder for me to focus and visualize a circuit in my head any more. I can still draw out circuits from memory but finding frustrating to say the least to have to even ask for help now. Medication you know. It's like trying to build something when you are all liquored up. I don't drink either, maybe that would help. If I sit down for a few minutes I suppose I can figure it out, but what are your ideas? maybe better than mine. One Idea I was going to use a 555 timer in one shot mode. Connect the PWM to the one shot so it continuously receives pulses. It times out each pulse that activates it, at 3 minutes, checks for power on condition and receives another pulse etc. I just thought of something, brain surge, maybe I am thinking too complicated. how about this: my PWM will drive the fan and supply pulses to the 555 timer which times out 3 minutes, 555 drives a transistor as a relay driver which keeps the relay on for 3 minutes each pulse that arrives at the input of the 555 that activates the 555. The relay switch or contacts will be in series with the fan power. The driver transistor and 555 will be connected to power source that will never shut off. So as soon as power is once again applied to the PWM it activates the relay, which allows power to be applied once again to the fan.
Any other ideas that might be simpler? My PWM will use a 555 driving a mosfet running at about 25 KHz.
