Need data for transistor
Discussion in 'General Electronics Chat' started by tinkerman, Nov 26, 2012.
  1. tinkerman
    Jul 22, 2012
    Can someone identify this device? Numbers stamped on it are T2141F
    Below that are numbers 0544
    It's in a case similar to TO-220
    There are two used in the output of this regulator for gen set so they are probably fairly high current rating expect 10A. Darlington??? One appears to have a short between pins 2-3.
  2. ARSiq
    Nov 23, 2012
    Hard to read, but basic is there.
    Type Designator: T2141F
    Material of transistor: Si
    Polarity: NPN
    Maximum collector power dissipation (Pc): 60W
    Maximum collector-base voltage (Ucb): 400V
    Maximum collector-emitter voltage (Uce): 300V
    Maximum emitter-base voltage (Ueb): 5V
    Maximum collector current (Ic max): 6A
    Maximum junction temperature (Tj):
    Transition frequency (ft):
    Collector capacitance (Cc), Pf:
    Forward current transfer ratio (hFE), min/max: 600MIN
    Manufacturer of T2141F transistor: Inchange Semiconductor
    tinkerman likes this.
  3. tinkerman
    Jul 22, 2012
    Nice. Saved as Favorite. Will be very handy I'm sure. Thanks again.
