Need current regulator circuit for 300 vdc, 1 mA
Discussion in 'The Projects Forum' started by Greg52556, Dec 7, 2014.
  1. Greg52556
    Dec 7, 2014
    Anyone know of a circuit (or component) to regulate my 300 vdc to 1 mA as the load decreases? I am doing electrolysis and the load decreases as the process continues, due to ion formation.
  2. ronv
    Nov 12, 2008
    3,398
    1,455
  3. Greg52556
    Dec 7, 2014
    OK. Source is 300 vdc, R1 is 10 kΩ, R2 depends on what I want to limit current to, the transistors are like BC547 and BD139 except they will be 500 volts. Did I miss anything? Thanks!
  4. crutschow
    Mar 14, 2008
    13,496
    3,373
    You forgot power dissipation. At 300V a 10k ohm resistor will draw 30mA and dissipate 9W so you will want to increase R2's value. Since you only need 1mA, you could increase R2 to about 10meg ohm or so.
  5. Greg52556
    Dec 7, 2014
    So to confirm:
    R1 stays at 10k ohm.
    R2 should be 10 meg ohm.
    This limits current to 1 mA with 300 vdc source.
    What wattage should R1 and R2 be?
  6. JWHassler
    Member
    Sep 25, 2013
    204
    34
    I think the resistor ref-#s got swapped: R1 is the larger one. 10 megohms sounds good and will dissipate .009 Watts
    R2 sets the current by R2=600/current_in_mA (approx 600 ohms) and dissipates .001*600 = .6 Watts
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    Yes, I meant R1 of course. :oops:
    Note that the 600 ohm R2 emitter resistor will dissipate .001^2 * 600 = .6mW.
  8. JWHassler
    Member
    Sep 25, 2013
    204
    34
    Oh gosh..... :oops: right back atcha, crutschow.
  9. Greg52556
    Dec 7, 2014
    Thanks! I'll let you know how it works.
