Need Clarification on current source and sink
Discussion in 'General Electronics Chat' started by guru200773, May 2, 2010.
  1. guru200773
    Apr 26, 2010
    94
    i have a doubt... what is current source and current sink? What is the difference between them and what is the use of Current source and current sink...? Explain with practical application of current source and current sink
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Here's a practical device that can be pressed into service in either mode - several practical applications are covered.
    http://focus.ti.com/lit/ds/symlink/ref200.pdf
    I'll let you do the research on the distinction between the two.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    They are much the same as what are the advantages of a power supply.
  4. VoodooMojo
    Nov 28, 2009
    503
    53
    this PDF explains it nicely.
    guru200773 likes this.
  5. guru200773
    Apr 26, 2010
    94
    thank u voodoomojo ur info is useful and superbly undestood.. thanks to t_n_k also
  6. VoodooMojo
    Nov 28, 2009
    503
    53
    guru,
    here is a boatload of more reference matter.
