are they facing each other,you could use infra red leds,Bluetooth,rf.
What does it mean to be "removed"? If I move it so that it is 3m away, does that qualify?my project is that... two objects are lying at a distance of 2 meters (not wired) if any of them is removed the other should start beeping ....and is it possible to put the third one also in the loop???all wireless ..
if the distance is more than 2 meters there should be a beeping soundWhat does it mean to be "removed"? If I move it so that it is 3m away, does that qualify?
Can other things in the environment change? If they are 2m apart, then someone could part a small car between them. Do they still need to know that the other is still there?
yesDo you max out at three object? Might you add a fourth or a fifth at some point? If you do, are you willing to modify all of the existing objects to accommodate each new object?
Uh oh, I think that means it needs to estimate actual distance, as opposed to merely detect a signal in range or not. Much trickier.if the distance is more than 2 meters there should be a beeping sound
there could be things between them it should work in the same way
So that rules out a LOT of techniques. You can't rely on signal strength at all since that is going to vary due to all kinds of things even if the objects remain stationary. And if you need to tell the difference between something being 2 meters away and, say, 2.1 meters away, then you have a much more challenging task.if the distance is more than 2 meters there should be a beeping sound
I asked (that you quoted) three questions. A single "yes" tells me nothing since a Yes to the first question is very, very different than a Yes to the third.
