Need Chinese label on my PWM Controller Translated
Discussion in 'General Electronics Chat' started by Judah, Sep 9, 2014.
  1. Judah
    Sep 8, 2014
    Hi All,
    I recently purchased a PWM controller for a treadmill I'm working on. Problem is it arrived with Chinese labels on all the terminals, and no supporting documentation - and unfortunately I don't speak Chinese. Ive checked the web and I've not been able to find a specs/data sheet for the product.
    So if you can speak chineese or know anyone who could translate the five chineese words for each of the five dual terminals, that would be an amazing help to me.
    Reading from left across the photo, I know the first dual terminal is the off/on switch, and the second goes to load Pot. But the last three I'm not sure the order. There will a supply voltage and a output to load terminal and obviously one other, but I'm needing to know which is which.
      File size:
      243.1 KB
      101
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Playing with Google translate English to Chinese ...
    1) Switch
    2) Potentiometer
    3) Potentiometer <something like move> out,
    4) Audio out
    5) Power <something> (probably some form of "input", but I know nothing of Chinese symbols)
    Try it out yourself, and see if you can find better matches. This may keep you busy until you can find someone who actually can read Chinese.
    Judah likes this.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    Calling Happyganl?
    (Our only active Chinese member, if I remember correctly.)
  4. absf
    Dec 29, 2010
    1,493
    374
    1) Switch
    2) potentiometer
    3) output
    4) magnetic output
    5) power input
    Can ScottWong confirm ?
    Allen
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    just emailed the pic to my chinese (computer) parts supplier, let you know as soon as i have an answer.
  6. Judah
    Sep 8, 2014
    Ok, that's awesome. Thanks heaps guys. I'll have to do a bit more research on what exactly the magnetic output is for. Still have a lot to learn at motorcontrol systems. Anyone know any good links with good info?
  7. Potato
    Sep 10, 2014
    5
    From left to right
    Switch
    Potentiameter
    Voltage Regulator Output
    Field Wave Output
    Power Input
  8. tom_s
    Member
    Jun 27, 2014
    287
    342
    answer (copy/paste email)
    Tom,
    From left to right:
    开关 电位器 +电枢输出- +励磁输出- 电源输入
    Switch Potentiometer Armature output Excitation output Power Input
    i was assuming power in was on the right as the fuse is located there
    cheers
  9. Potato
    Sep 10, 2014
    5
    The first word "励" means "to excite"
    The second word "磁" means "magnetism"
    Combined both of them means "magnetized excitement", or in technological parlance, waveform, field wave, or some kind of "graphs"
  10. Potato
    Sep 10, 2014
    5
    The meaning of "电枢" is "armature", but in this case, the one in the photo has more to do with "regulating the voltage" which supplies how much voltage you apply to the armature (or the motor) to speed up (or slow down) the spin speed
  11. Judah
    Sep 8, 2014
    Ok thanks Potato. That armature output be the terminal controlled by the pot. This is handy as I wasn't to clear on which output to use,
    Thank again all
  12. Vinny Galbo
    Sep 11, 2014
  13. kubeek
    Sep 20, 2005
    4,687
    805
    How exactly do you expect him to write down the chinese characters? Google tranlate at least has a feature where you can try to draw them and then choose the most similar one, I don´t see anything like that on babelfish.
  14. tom_s
    Member
    Jun 27, 2014
    287
    342
    copy / paste :)
  15. kubeek
    Sep 20, 2005
    4,687
    805
    Well, once someone has typed it here then copy paste is obvious. I was referring to the first post, where all you got is a photo of a chinese text.
