Need assistance reversing hand drill
Discussion in 'The Projects Forum' started by coolmack, Jun 12, 2016.
  1. coolmack
    Jun 10, 2016
    11
    I am trying to reverse a hand drill with a DPDT switch, need a little help on how to wire it.
  2. Dodgydave
    Jun 22, 2012
    5,166
    776
  3. MaxHeadRoom
    Jul 18, 2013
    10,862
    2,525
    Presumably it is a mains powered drill and not battery portable?
    Max.
  4. coolmack
    Jun 10, 2016
    11
    Yes this is an electric older Bosch 1/2" hammer drill model 1198VSR. The fwd/rev switch was bad, but could not find the original replacement so I thought I would try to a DTDP switch.
  5. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Personally I would have my hand go the other way on a hand drill..
    GopherT likes this.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    With most regular corded electric drills - reversing it will unscrew the chuck.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Can you post a picture of the switch? I had a similar tool (not Bosch) in which the switch "went bad" but there were an extra set of contacts I could use.
    As for the comments about the chuck coming off, many drills (also lathes, mills and other quality tools) are made to be reversible. The chuck doesn't unscrew. Either there is a locking screw on the inside of the chuck, the chuck is a taper fit to the spindle (J33 is popular for drills), or there is some other locking mechanism.
    Finally, can't you get the part from Bosch? That is really a quality tool.
    John
  8. ian field
    Oct 27, 2012
    4,459
    792
    I've seen a few expensive Bosch tools that weren't ant better than cheap & nasty Black & Decker.
    "Reassuringly expensive" doesn't always work like that......................
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
    @ian field
    More to your unsubstantiated and silly point, please give the model number for a Bosch reversible drill (hammer or regular twist type) with a RH threaded spindle.
    Best regard, John
  10. ian field
    Oct 27, 2012
    4,459
    792
    The TS didn't initially make it clear that the drill was originally reversible - in the vast majority of cases the chuck is simply screwed on.
    Cordless usually have a keyed or non circular shaft and the chuck is secured by a bolt through the middle.
    The common type for reversible mains drills is the SDS type chuck - or Morse taper for the real heavy duty stuff.
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    The TS, post #4, made it clear it was a Bosch, reversible hammer drill. What is so hard to understand about that?
    John
  12. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Thats a little harsh but unit might not be designed to have reverse for a reason like the gearing or the hammer mechanism
  13. djsfantasi
    Apr 11, 2010
    2,911
    881
    Why would a REVERSIBLE drill NOT be designed to have REVERSE? I am confused?
    And why would it have a forward/reverse switch?
  14. coolmack
    Jun 10, 2016
    11
    Well seems like everyone is cutting each other down while the question @ hand is still on the board.
    I have had this hammer drill for many years & the original fwd/rev switch went bad on me last year. I have tried to get the original switch from Bosch, ereplacement, and a few other online companies, but the switch they send me is not the original and will not work. So I have decided to replace the switch with a simple DPDT switch, just asking for a little help from someone that could help me wire this up without burning the motor up, too good of a hammer drill to throw away.
    GopherT likes this.
  15. coolmack
    Jun 10, 2016
    11
    I use it a lot & it being a hammer drill, it does need to reverse sometimes.
  16. coolmack
    Jun 10, 2016
    11
    What silly point? Either you can help me or you can't!!
  17. coolmack
    Jun 10, 2016
    11
    Precisely!!
  18. coolmack
    Jun 10, 2016
    11
    Originally, it came with a fwd/rev switch, used it many times. SWITCH WENT BAD!!
  19. coolmack
    Jun 10, 2016
    11
    The model # is 1198 VSR 1/2" Hammer Drill.
  20. coolmack
    Jun 10, 2016
    11
