Need Assistance on a selecting a quick connector
Discussion in 'General Electronics Chat' started by Seaker, Mar 26, 2013.
  1. Seaker
    Feb 3, 2013
    32
    Greetings all;
    I am working on a project that has seven thin wires running from a outside source to a project box that I am working on.
    What I want/need is to have a plug of some sort that can easy and quickly connect the wires when removing the PCB from the external censer.
    As a side note the external wiring that is used is CAT5 cable with 7 of the eight wires being used.
  2. crutschow
    Mar 14, 2008
    13,493
    3,372
    A DB9 subminiature connector is a commonly used connector with 9 pins.
  3. Seaker
    Feb 3, 2013
    32
    Thank you Crutschow.
    I was hoping that there might be some other responses that might prove beneficial.
  4. mcgyvr
    Oct 15, 2009
    4,789
    974
    There are tons of connectors that work..
    te.com take your pick..
    How about just using rj45 modular jacks/plugs to go with the cat5 cable.
