I was just playing around with LTSpice (only started using it last week) and was trying to compare the benefits of arranging an array of potato cells in series versus parallel. Please keep in mind I'm a beginner hobbyist who's read up through middle of chapter 7, volume 1 thus far (had them all printed!), so try and keep your explanations somewhat simple if possible .
I set up two circuits (A and B) making use of the same 3 potatoes and same hypothetical load. I had anticipated that the parallel potato circuit (A) would produce more current to the load than the series potato circuit (B). This was indeed true (ALoad versus BLoad) but the improvement was only from 1.07m amp to 1.5m amp. Likewise, the voltage, comparing A1 to B1 seems off somehow also. I would have thought B1 would be 1.5v and A1 would have been .5v.
I think the thing that's throwing me off here is having parallel/series power sources versus parallel/series loads off of a single power source. Likewise, I wasn't completely sure I set up the "internal resistance" of each of the potatoes correctly. I took a potato, stuck a zinc screw and penny into it, grabbed my multimeter, and measured roughly 400ohms of resistance, so I "think" I set that up correctly, but maybe not?
Any insight/help you guys could offer would be much appreciated. I've attached both a picture showing both circuits and the results as well as the LTSpice file should anyone need to reference how I set things up.
