Need Advice
Discussion in 'General Electronics Chat' started by swapnilnimbalkar, Apr 23, 2013.
  1. swapnilnimbalkar
    Apr 10, 2013
    8
    Please refere to the circuit attached herewith......
    What this circuit does
    When i press the switch SW1 LED1 glows for few seconds then it goes dark and LED2 Glows > it goes dark and everything stops until i press SW1 again.
    In the circuit attached herewith i have few question.
    1. Can I replace LED1 with a DC Motor (3-6v toy dc motor)
    2. Suppose it is running in forward direction.....
    3. Then can i attach output of 556(2) to the same motor above with reverse polarity?
    Will this circuit work? I want to run motor in Forward direction then in Reverse direction.
    Thanks.
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    To reverse the direction of the motor you will need a mechanical relay or an H-bridge.
  3. swapnilnimbalkar
    Apr 10, 2013
    8
    can you give me circuit diagram of H Bridge modified for the purpose mentioned above?
