Need advice for a project
Discussion in 'General Electronics Chat' started by lruss, Dec 28, 2010.
  1. lruss
    Dec 28, 2010
    Hi everyone!
    I wonder if you can give me an advice - I am looking for a linear motor (12V sealed), nothing outrageous: 3-5 cm travel, 100n linear force, preferably self-retracting if power is lost. Size is not the main issue as long as it's somewhere within the 3"Dx10"L margins.
    Thank you in advance!
  2. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    You could try linear actuators. You can find these on:
    http://parts.digikey.com/1/parts-kws/linear-actuator
    If you have time and a drilling machine probably you could couple a bolt and nut with a metric thread to D.C. motor so that you get finer pitch.
    Wonder if solenoids could be used?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    It is a common misconception that metric threads are finer than inch threads. Remember, in inch, we have two common series (plus others); the most common metric has just just one choice. Of course, you can make any thread you want in either system.
    Compare some common metric sizes that might be used for a hobby lead screw with corresponding inch sizes using the very common series of fine pitches.
    Code ( (Unknown Language)):
    1.
    2.
    3. Inch Size      Metric Equiv.      Approx. Metric Equivalent
    4.
    5. 1/4-28           6.35x0.91            M7x1 or M6x1
    6.
    7. 5/16-24         7.03x1.06            M8x1.25
    8.
    9. 3/8-24           9.5x1.06             M9x1.25
    10.
    11. 7/16-20         11.1x1.27            M11x1.5
    12.
    13.
    Thus, the inch fine thread series has a slightly finer thread than metric. More important, hardware for it is more widely available to consumers in the US and usually considerably cheaper.
    John
  4. shortbus
    Sep 30, 2009
    4,096
    1,692
  5. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    Pls choose an inch thread as per John’s advice. I didn’t know inch threads have finer pitch and cheaper in US.
