I have a need to basically daisy chain 6 USB Charger cords in a custom box
I have a USB Charger wall plug:
Input 5V
Output 4.2v 500mA
A cable with a special end tip plugs into this wall plug and charges an electronic cigarette that matches this voltage. I want to build a small box with just the special end tips wired to a power supply (6 end tips in a small box with one cord to the wall).
I do not know much about electronics but I am not a simpleton either.
I can solder and figure things out mostly.
What I need to figure out is how to go about this. I can strip the special ends off of the cables leaving the pos/neg and then wire them, cut holes for them in the top of the box and glue, but not sure what I should wire them to inside the box.
1. Could I simply wire them to a lamp cord? (I know this isn't right or safe)
2. Should I disassemble 6 of the wall chargers and wire each one individually to the special end and then all to a lamp cord? (I know this isn't right or safe)
2. Should I disassemble 6 of the wall chargers and wire each one individually to the special end and then all to a disassembled 6 outlet power strip?
4. Is this a stupid idea?
I have seen these out there so I know it's possible, I just don't know enough about power to make it workable.
Input 5V
Output 4.2v 500mA
