Need adjustable 12V trigger for relay
Discussion in 'The Projects Forum' started by tuuluser, Jan 12, 2012.
  1. tuuluser
    Nov 20, 2011
    23
    I need to trigger a 12 relay. The positive rail varies from 10-15V and the negative rail is zero. I want to be able to adjust the trigger between 11 and 12.5 volts. I don't have a 5V supply or fixed voltage reference in the circuit.
    I guess I could use a linear voltage regulator for the reference and a 741+BJT schmitt trigger for the switching, but that seems to require at least 3 IC's and a voltage divider and a trimpot. I don't have that much room in the board.
    Is there a simple, small footprint way to do this? Maybe a single IC with a reference and schmitt combined. A diode, trimpot, and a BJT?
    The threshold voltage does not need to be precise. Basically, I want to use the relay to 'wake up' a circuit when the battery charge reaches a certain level, and disconnect when it drops below a certain level, so I need a little hysteresis.
    Thanks for any ideas.
  2. tuuluser
    Nov 20, 2011
    23
    OK, maybe I could clamp the reference on a schmitt with a 10V zener. Then I would just need an op-amp, a resistor and trimpot for the input voltage divider, and a BJT to switch the relay. Still to big of a footprint.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    You could do it with a TL431 and a transistor and 3 resistors. I posted it somewhere here, I will need to do some research, don't have anything to draw here.
  4. praondevou
    Jul 9, 2011
    2,936
    489
  5. tuuluser
    Nov 20, 2011
    23
    Thank you, praondevou. That is what I am looking for. I put together a sketch of an adjustable voltage switch. It looks like I can skip the transistor since the relay coil current is less than 20mA and the TL431 can sink 150mA.
    What about stability, or hysteresis? I am only using this circuit to activate the relay ( adj @ 11.5V - 15V ). I don't need the circuit to turn off the relay if the voltage drops below a minimum, that is handled by another circuit. But I don't want it to chatter around the turn on voltage. In fact, I don't mind if it latches.
    Would R4 work for this?
