Need a Square root circuit
Discussion in 'General Electronics Chat' started by pawan_gupta, Jul 17, 2004.
  1. pawan_gupta
    Jul 17, 2004
    Hii Friends,
    I am new user on this great site. I need a square root circuit using MOS transisters. The input voltage very from 1 V to 3 V. If any body have any idea for this circuit, please let me know.
    Thanx in advance.
    Pawan
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    it's been quite a time nobody has replied to this post. maybe your post is not clear enough to be understood. pls. clarify what do you mean by a square root circuit. :unsure:
  3. pawan_gupta
    Jul 17, 2004
    Hiii Mozikluv,
    I have got a square root circuit, which can give square root signal of input signal. But the problem is that, i have got square root signal which can vary from 100mV to 300mV, and i want to increase this signal from 1V to 3 V. So can you please suggest me which type of amplifier i should use. Since 100mV to 300mV can not open NMOS switch, that's why i can not use simple amplifier or OPAMP.
    Thanx for your reply.
  4. mozikluv
    Jan 22, 2004
    1,437
    hi,
    ok igot the idea. would you like to use a microvolt input op-amp. even if you use a regular op-amp it will amplify your 100mv to 300mv to any level that you want so it can drive whatever power transistor you will use.
  5. pawan_gupta
    Jul 17, 2004
    Hii,
    I have got low voltage OP AMP by using PMOS instead NMOS. Thanx .
    Now i have another problem. The problem is that i have a clock pulses. I need a hardware which can give me a high voltage (logic high, may be 5 volt) at the first rising edge of that clock pulse. That meanse output initally will be low but after first rising edge of clock it become high and remains high until power goes off.
    If anybody have some idea about this, please let me know.
