Application: I'm a neuroscientist who knows just about enough about electronics to get myself in trouble. I'm trying to built a biological DC stimulator that works the way I want it to. This involves getting an appx. 54V DC input signal to be slowly modulated between 0V and appx. 54V with control sequencing dictated by me. In short, I need to know how to modulate the output of an NPN transistor such that the emitter voltage is proportional to the supply voltage from near 0V to near the collector voltage (+54V) or even if it can't be done and I'm wasting my time.
Problem: I don't know what to call such a circuit, hence it is difficult to find answers to questions I have for constructing it.
Synopsis: I need to design a small circuit that will ramp a voltage from 0 to 98% of supply V up or down. In my particular case, the supply voltage (also the collector voltage) is +54-58VDC (six 9V batteries connected in series, with fresh batteries this yields about 58VDC). I would like to use an NPN transistor such that the CE voltage can be adjusted from near 0V to at least 98% of the supply voltage by changing the current to the base. The current in the circuit after the power supply is regulated to 2.5mA at 54-58V by a current regulator diode. So, there are no particular current handling issues that I predict. The current in the control part of the circuit will always be 2.5mA. In the final working system, the signal to the transistor base will be supplied by an Arduino Due 10-bit DAC (which I think is 1024 steps between 0V and 5V). So, I would like to be able to get the Arduino's DAC to be able to ramp the voltage of the requested circuit's output up and down between 0V and 54V at relatively slow speeds (> 1sec for full ramp). I'm not worried about the DAC output, and how to handle it to do what it needs to do. What I need to know is, how to control the proportion of the supply voltage that gets output from the transistor's emitter. So, for the breadboard circuit, I can use a pot to simulate the output of the Arduino's DAC.
When I first sat down and tried to lay this out in a simulator, I thought it should be an easy task. I soon realized, however, that my knowledge of the workings of an NPN transistor is apparently very limited when applied to DC analog circuits. So, I would appreciate suggestions as to the circuit I'm trying to build, or where to go to learn what I need to know to do it on my own.
