Need a simple on/off timer 12V 10A 1-60 sec
Discussion in 'The Projects Forum' started by coas, May 18, 2009.
  1. coas
    May 18, 2009
    I'm looking for a simple countdown timer, adjustable from 1-60 sec, turn knob, power on set time with start switch, off when reaching zero.
  2. mik3
    Feb 4, 2008
    4,846
    63
    If you don't need a high accuracy timing you can use a 555 monostable circuit with a pot to adjust the time intervals. Otherwise, you will need a digital timer with buttons to set the time.
  3. coas
    May 18, 2009
    How not accurate will it be? And where can I get a digital timer as you mentioned?
    It will be used in a DIY fuel injectors test bench for measuring injectors flow volume in 20 sec. Injectors pulse is 2-6 ms.
  4. mik3
    Feb 4, 2008
    4,846
    63
    You can buy a wall wart timer digital timer, like the ones used in the kitchen to turn off appliances after a time interval.
  5. foundit
    Mar 9, 2008
    8
    if you have 50Hz AC current try to use this old IC, SAB0529 from Germany
    you can find the datasheet on http://www.alldatasheet.com
    wish that helps
    best regards
