need a simple digital clock circuit
Discussion in 'The Projects Forum' started by Major Aspsial Asadullah, Nov 22, 2007.
  1. Major Aspsial Asadullah
    Nov 22, 2007
    hi,
    I am new in electronics i m doing BS Tele communication engineering i want to construct a simple digital clock I want your help
    Suggestions are welcomed
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    I remember that there was one chip with almost all the circuitry needed for a digital clock. Only the LCD/LED display, the buttons and the PSU (of course) were to be added. But I don't remember the reference.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Got one on an old clock. Of course, General Instruments is no longer in business.
  5. Voltboy
    Jan 10, 2007
    197
    You could try with the LM8562 - Digital Alarm Clock. It also contains an 7 segment display output and alarm.
    Edit:I did a search and didn't found a supplier for the LM8562, but you could try with the DS1302 from Maxim IC's.
  6. mozikluv
    Jan 22, 2004
    1,437
    check this out http://transistor.20m.com/clock.html
    if your not keen on micros maybe you can try several chips like;
    7400 - TTL quad nand
    7473 - TTL JK Flip Flop
    7447 - TTL BCD 7 segment Decoder/Driver
    7413 - TTL Dual 4 input Schmitt Trigger (if you could still find one)
    7490 - TTL Decade & Binary Counters
    however this functions in a 24 hr. mode
  7. Major Aspsial Asadullah
    Nov 22, 2007
    Great thanks to all who helped me
    i m very thankful all of you
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Well...isn't that the company that calls itself Microchip? Seems to me the original PIC 16C54 was a General Instrument part.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That may be, but the chip was the first LSI ic. It was in a Heathkit digital alarm clock that also used Sperry-Rand displays that were a neon seven segment equivalent of a Nixie tube. After 35 years, it may be hard to find.
