Need a relay or other solution for 250v 50 amps?
Discussion in 'The Projects Forum' started by XOIIO, Apr 1, 2013.
Thread Status:
Not open for further replies.
  1. XOIIO
    Mar 1, 2013
    39
    Hi, I am starting work on a coil gun, I am going to use a nerf longshot as the body for it since there is a fair bit of room and it looks good in black.
    Anyways I just salvaged two 250v 4400uf capacitors, and I need a solution to trigger them. I have found relays rated up to 70 amps but the voltage rating is where the problem lies. I want to use something like a relay, or some other method that can be triggered by a lower voltage. I am going to have a small lever switch behind the trigger, and that is what will fire the coil gun.
    What can I use to accomplish this? Are there relays that meet these specifications? Are they super expensive? What other solution could I use?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You should read the TOS since this project is probably out of bounds.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    This thread violates the AAC Terms of Service, Chapter 6 on Rail/Coil guns. Therefore it will be closed.
    Thank you for your understanding.
  4. XOIIO
    Mar 1, 2013
    39
    ahh shoot :/
Thread Status:
