Need a little bit of info on equalizers
Discussion in 'The Projects Forum' started by EarlAnderson, Feb 7, 2012.
  1. EarlAnderson
    Nov 13, 2011
    166
    Hi! I am planning to build a graphic equalizer, which I will probably use for my guitars and such. I just need a little bit of info on Equalizers, such as how the circuitry works. A schematic of a simple bass control circuit (or 1 band eq) would also come in handy, just to get me started
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    An audio equalizer can be simple bass and treble tone controls that boost, cut or adjust anywhere in between.
    More advanced tone controls add a mid-frequency boost and cut control.
    Complicated equalizers use many active filters that boost and cut many narrow frequency bands.
  3. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    I'd say get a premade eq and insert it in an effects loop.
    Building one is just too much work for what its worth as you get past 3 bands.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
  5. EarlAnderson
    Nov 13, 2011
    166
    I think I understand a little better now. I was Filtering certain frequencies with a passive band pass filter, then amplifying them, then trying to mix it with the original signal itself (which was an EPIC fail by the way). But now I understand that you have to use active band pass filters in order for it to work properly
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
  8. dataman19
    Member
    Dec 26, 2009
    136
    29
    So why a graphic EQ?
    Most musicians like the parametric....
    Better control and a lot less hassle..
    Dataman19
