Need a little bit of help.. (7447 and 7493 ICs)
Discussion in 'The Projects Forum' started by xtianrae, Mar 17, 2010.
  1. xtianrae
    Mar 17, 2010
    I need a schematic diagram that would demonstrate both the 7447 and 7493 ICs.
    And also a PIN configuration of a dual 7 segment LED display.
    I suck at this.. Any form of help would be very much appreciated.
    Thanks in advance, guys.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Welcome to AAC.
    How would you like the demonstration to be and what type of 7 Segment you have
  3. xtianrae
    Mar 17, 2010
    Well, the problems I have posted here are exactly the ones given by our professor without further specifications. Yeah.. as is.. o_O
    So I guess any would do..
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    is it that all the devices should be in 1 diagram.
    By the way, where are you from?
  5. xtianrae
    Mar 17, 2010
    Yes, both ICs in only 1 diagram.
    Electronics really isn't my stuff.. Had it only not been one of my subjects haha.
    I'm from the Philippines. ^^,
  6. retched
    Dec 5, 2009
    5,201
    313
    R!f@@ likes this.
  7. xtianrae
    Mar 17, 2010
    Oh.. Hm thanks..
    How about the LED PIN config?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oops - Retched, it's a 7447, not a 7474 - the later is a dual-D.
    retched likes this.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You know, this is a class assignment.
    What you need to do is find the datasheet for the LED display, and figure out which pins do what from the datasheet.
