Need a design to Illuminate LEDs for 2-3 minutes with a momentary switch
Discussion in 'The Projects Forum' started by tfhasenstaub, Jun 23, 2016.
  1. tfhasenstaub
    Nov 9, 2014
    Need some advice on a circuit design to drive some LED's for about 2 to 3 minutes. I need to trigger with a momentary switch. 12vdc 5amps max. Are there any cost effective available components out there or any example circuits?
    -Ted
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Welcome to AAC!
    Your question is more suited for the Projects Forum.
    Good luck!
  3. GopherT
    Nov 23, 2012
    6,315
    4,039
    An LM555 or NE555 will work well as the chip. Also, a good MOSFET transistor like an IRF530 will work well in the circuit below.
    Bernard likes this.
