For those that don't know, the "U" designates "1 standard unit" for a rack-mount computer system which is ~ 1.75" per unit, so 2U is 3.5" x 19" wide and I can do 21" deep max. IT will look something like this but will have all kinds of inputs and outputs on the front panel and rear panel. This unit will fit directly under my central monitor stand (2 monitors stacked on top of each other. There are 2 more identical spaces on either side of the monitor stand which can allow for placing some components in those spaces should it be necessary. Basically just a slim panel that has some items that may not fit in the main central docking hub.
This system is going to bring all the ports of my tower computer to the front of this case which sits under my monitor as the PC is not easily accessible.
It is much more beneficial to make this case out of aluminium and or steel/Al combo possibly with some acrylic top, sides or front in some places.
It could look something liek this - but with a lot more connections on the front panel.
I have a long list of components going into this that will make this "hub/docking station" totally awesome!
and I'm goig to have to make a number of PCB's which will be a challenge since I've never done this before.
I' need to know if any has any experience making cases like this (outer shell, I can handle the inside) and if so, do you do them yourself or do you have a person who can do it. I'm willing to pay, so any help here is appreciated.
If anyone finds this interesting I will post a list of all the items that I will be adding to the mix, it quite a selection!!!!!! and should be compatible for at least a decade or so in the future, in my estimates.
The hub/dockig station will have the following:
Front Panel
Computer power & reset switch,
HDD LED from computer,
(2) PCI-E x1 risers
(1) PCI-E x4 riser
DVD or Bluray drive,
3.5" HDD slot w/ caddy & converter for 2.5" drive,
memory/SD/microSD card & Compact Flash readers,
Sata controller card connected to PCIe x1 slot
SATA data & power connections,
USB 2.0 & 3.0 hubs,
4 pin molex power.
Cat6 ports (pass through to back panel, where they connect to router, 5-8 port managed switch (optional - to jump to one of the RJ45 connections to give more ports),
1/4" head phone plugs,
Mic input,
Line-level input,
line level output, audio selector for speakers vs headphone or for both,
HDMI in & out ports on front & back panel (depends upon build needs),
AC power outlet
System Tep readouts (CPU, video, HDD, etc)
Front facade will probably have some kind of carbon fibre veneer which comes in many colors.
Rear panel
AC power input with fuse/breaker to power everything inside
120v outlet for monitors
RJ45 connections (# needed dependent upon set-up)
USB 3.0 (maybe 3.1) to connect to System
HDMI inputs from computer (VGA or DVI-x if needed)
HDMI outputs to monitors (VGA or DVI-x if needed)
Internal components
DC power supply (PC supply) 12, 5, 3.3v & ground outputs
48v DC PSU - 875w ( ~ 18A)
Variable voltage output - 1.2v - 37vdc (Might be able to get something better here)
Internal fans possibly (SILENT FANS!!)
Possible PC fan controllers - speed & temp readout
Multimeter w/ 3 wire terminals
Possibilities:
2-5 channel audio amplifier for speakers (2 x 30w or 5 x 20)
Raspberry Pi B+ unit with ports "broken out" to front panel for access
component A/V inputs & outputs, digital, S-video & optical (depending upon needs)
Some neat LED lights and possibly neon accents if desired
I'm sure there are some think's I've forgotten and some items might not make it into the project. I'd ove to hear people's thoughts. This is for a computer & electrnics tech so all this stuff will be used pretty often.
If anyone has any desire of making something similar I would really like to collaborate on ideas and possibly production. I'm really stuck on the case design now as I don't have the ability to bend aluminun or steel of this size ad thickness.
Front Panel
(2) PCI-E x1 risers
(1) PCI-E x4 riser
USB 2.0 & 3.0 hubs,
4 pin molex power.
Mic input,
Line-level input,
AC power outlet
Rear panel
Internal components
Possibilities:
