I need to charge a battery from a PMBLDC generator of 24V 5A. The battery is 12v 2ah.
Lead acid batteryWhat kind of battery?
Trucker's supplies do 24V to 12V adaptors for running things like 12V portable TVs off the truck 24V system - a neat little solution, but it'd need a bit of modification to make it suitable for battery charging.Build or buy?
TI, Linear Tech, and Maxim make both switching and linear battery charger control chips. A really smart charger circuit starts out in a low current constant voltage mode to bring a deep-discharged battery up to a safe charging level, then shifts to constant current mode to pump in the watts, then shifts back to constant voltage mode for trickle charging to keep it topped off. Most chargers use only 1 or 2 of these stages.
ak
You can buy made for the job lithium jump start packs.I'm in almost the same situation. I have a 12V car battery that measuring 11.2v and my car will not start. I have a cordless drill battery which is 18V, can't I quickly top up my car battery without damaging anything??
You could go and get a proper automotive battery charger being your 18-volt battery maybe has 1.8 Ah of power in it and to get your vehicle battery up to the point where it can start the engine might require 5X that amount of Ah to recharge it.I'm in almost the same situation. I have a 12V car battery that measuring 11.2v and my car will not start. I have a cordless drill battery which is 18V, can't I quickly top up my car battery without damaging anything??
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
