Hi -
I have an instantaneous switch that completes a circuit ... for the solution (gps-based) to work, the circuit needs to be closed for 2 seconds or as long as the switch is closed.
My problem is obviously when the operator closes the switch for less than two seconds ... would someone describe how to delay the opening of the circuitfor 2-3 seconds (exact time is not critcal)? It is ok if the same delay comes after the switch is opened, regardless of how long the switch is closed.
Thanks!
Thanks!
