Need 7 and 9 megaohm resistors, where to get?
Discussion in 'General Electronics Chat' started by ScottCT, Oct 19, 2015.
  1. ScottCT
    Feb 17, 2009
    For a Heathkit VTVM, need 1% resistors at least 1/2 watt, 7 and 9 megaohms.
    Any idea where to get them, Mouser and Digikey no have.
    TY
    Scott
  2. GS3
    Sep 21, 2007
    408
    35
    What's wrong with 1 Mohm resistors in series?
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,390
    653
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    Why do you need at least half watt?
    It would take at least 2,100V to dissipate 1/2W into a 9Mohm resistor.
  5. KeepItSimpleStupid
    Mar 4, 2014
    1,293
    225
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,293
    225
  7. strantor
    Oct 3, 2010
    4,302
    1,989
    When I googled "Heathkit VTVM" I saw a bunch of VOMs that only measured up to 15VDC.
  8. GopherT
    Nov 23, 2012
    6,330
    4,078
    They are reference resistors for the vacuum tubes. I think 1/2 watt is recommended to limit heat extremes of "properly" sized resistors and limit heat effects on accuracy.
    strantor likes this.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    Got it, thanks!
  10. ScottCT
    Feb 17, 2009
    The 7 and 9 megaohm are part of the main voltage divider reference. The existing ones have drifted a little high, which throws off
    voltage readings. Ohmcraft might be a possibility if they will sell one off. TY Keepitsimple
  11. umphrey
    Member
    Dec 1, 2012
    39
  12. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Here's a search at Mouser that gets pretty close. 9.09M 1/2 Watt, 6.81M .4W, in stock. Monkey around with the filters for other close ones. Lots more 1/8Watts. Maybe parallel a couple. Vishay is a good go-to for things like this.
